What areas do I gluvit?..(with pics)
jtrom
Do I gluvit just the rivets of the rib or the rivets AND the seam of the rib? seems like I lot of Gluvit if I use it around the entire edge of the inside ribs.
jigngrub
Re: What areas do I gluvit?..(with pics)
All seams and rivets below the waterline, then paint over Gluvit to protect it from the sun.
jtrom
Will a 2 pound kit do this entire 15 ft runabout?
Woodonglass
Sure will with some left over probably. It really flows so if you can rock the boat, while it's setting you will get it to flow into all the cracks and crevices.
ezmobee
The 2 pound (or quart, whatever you wanna call it) was enough to JUST finish all the rivets and seams in my 18'. No need to paint over it if you're going to have a deck in the boat.
jtrom
Ok thanks guys!........I'm not installing the deck until the spring. Should I paint over the gluvit for good measure?
sje0123
Paint, tarp, or flip her over. UV eats away at the Gluvit.
ezmobee
No. Just throw a tarp over the boat. It's not like it breaks down immediately.
