what brand of prop
boatnut74
i have a mercruider pre alpha and am looking at getting a couple new props. Solas price seems hard to beat but are they comparable to the others. thanks
steelespike
Re: what brand of prop
Generally the Solas props have been predictable and have good results.However with prop selection results can sometimes be surprising.
walleyehed
If it's a pre-Alpha, make sure your current prop is cupped...if it's NOT, reduce 2" for new cupped prop. And yes, Solas aluminum props are as good as anything I've tested in that material.
craze1cars
Walleyhead, I found it interesting you specified "aluminum" in your response. Do you have a less favorable opinion of their stainless props? I have a Solas stainless I have been very satisfied with. But admittedly I have never had opportunity to do direct comparison with anything else...
jkust
I bought a Hustler alum prop for my boat last year for my sig boat and of my many complaints and general let down, the material seemed much softer than the oem Black Max. Although it was the same pitch as my BM, I lost several hundred RPM's equating to 4 or 5 mph. It has exhaust holes on the side and so sounds a little more agressive. They are very cheap however. On the plus side, I could not make it ventilate no matter how aggressive the turn or how high I trimmed. I could trim it up to the point that at WOT it would shoot an impressive rooster tail I though not possible with this boat. It provided alot of nice bark but no actual bite.
steelespike
He may have refered to the al prop because of their predictable and usually good performance especially compared to any stainess prop at about triple the cost.
There is no doubt a ss prop can usually improve overall performance over most aluminum props but that could vary from a few mph to a few tenths of a mph.
It seems that the Hustler props have a reputation for both surprisingly good performance and surprisingly poor performance.Sometimes to the point of wondering if they are miss labeled.
They are a really agressive prop and need to be selected carefully.
