what can I use for outdrive oil
aggiedave98
For my '89 Invader w/ the 3.0L Mercruiser Alpha I, what are the thoughts (I'm sure there are plenty) of Quicksilver oil versus other gear oil that I can get at walmart?<br /><br />thanks!
Haut Medoc
Re: what can I use for outdrive oil
I use Merc....It's readily avaiable....& I never worry if I am using the wrong stuff.....JK
crazy charlie
Walmart carries penzoil which is fine.A synthetic is a better choice.Quicksilver is always a good choice.Its hard to make a bad choice with any of these.Charlie
tommays
the marine oils like merc HP lube will drain out of the drive if any water gets in much better than a normal oil<br /><br />tommays
aggiedave98
If I use Penzoil or similar, do I use gear oil? Which one? Isn't there 80W, 80W-90, etc?<br /><br />thanks.
Bt Doctur
80/85/90 Hypoid works nicely.
vipzach
Originally posted by aggiedave98:<br /> If I use Penzoil or similar, do I use gear oil? Which one? Isn't there 80W, 80W-90, etc?<br /><br />thanks.
Are you asking if you should use gear lube or motor oil?<br /><br />You definately use gear lube. I personally use the High perf gear lube from merc, like JK said, I don't have to worry about if it is right or wrong.
Ayuh,...........<br /><br />Mobil 1,.... 75W90 Syn. Here.......... ;)
aggiedave98
nope, wasn't asking if I use motor oil, but there are different weight gear lube... the Penziol recommended is 80w90 and apparently the mobil 1 is 75w90...
Penzoil is Also 75W90 in the Full Syn.........
rodbolt
I use the quicksilver HP gearlube in all merc V6 and mercruiser gear cases. its good stuff.
