jumbofordman
Thread starter- Joined
- Aug 27, 2010
- 20
I have a 89 Mercury 150 (ser# between C100861-C239552,) it was sitting up for 3 years when I bought the boat. It's on a 86 Checkmate Predictor 17'.
I'm gradually getting it running correctly, but it's running really rich at idle. So rich, in fact, that it won't idle unless you give it a little throttle, and with the control I have, it's difficult to get it into gear (you have to move the throttle back and then quickly into forward.) Makes docking fun, too.
I've run a compression test, getting between 118-122 in all cylinders. The PO to the PO fiddled with things a bit, and I'm suspicious that he changed the jets, so I'm trying to determine if I have the right idle jets in there.
Right now it has .046 idle jets and .074 main jets.
The numbers stamped on the carb (from block flange outwards) are:
1274-5427-0 WH
157-
155
41-11458
Supposedly I'm looking for a couple of digits after the WH, but it's blank on all three carbs. I have already taken the carbs apart, cleaned them, reset the floats, put them back together with new gaskets. I fix older trucks and Jeeps, so I do have some carb rebuilding experience.
1274-5427-0 WH
157-
155
41-11458
