1996 Evinrude 225hp v6 Ocean Pro<br /><br />prop: OMC SS 15 x 17<br /><br />Was cruising offshore at about 30 mph when the rpm's shot up. Thought I lost the prop. Anyway, I got in the water to change the prop out with the spare I had. When I took the nut off I could see black rubber oozing out around the prop shaft. I took the prop off and there was melted black rubber all over the thrust plate and the hub was toast. The thrust plate was seized up on the prop shaft and I couldn't get it loose so I just put the spare prop on off we went.<br /><br />Does anyone know what could cause the rubber bushing to melt down?
