skydiveD30571
Thread starter- Joined
- Feb 13, 2012
- 1,042
For the SX drives, specifically the sx-a drives, what can cause this? My idle speed is 700 in neutral, new TFXtreme shift and throttle cables, adjusted several times to ensure correct fitting. Cable fully extends bellcrank into both forward and reverse settings. Shifting into forward is seamless and quiet. Shifting into reverse gives a thug and is much more noticeable. I've never dove into the gearing of an outdrive before so I'm trying to understand what can cause this into reverse only. 2nd owner with no maintenance history, 2007 SX-A 1.60 ratio.
