powerslide
Thread starter- Joined
- Feb 5, 2012
- 47
Tested the boat out on the muffs. Not knowing much about boats it appeared all was good. Guy said he replaced lower unit on this motor about a year ago. So me and a friend went for a test run this past weekend. Well the boat wouldnt hardly idle without using the fast idle lever. after letting it warm up awhile it ran good enough to back it off the trailer. we got it off and he came back to get me as i got on and he started to back out the buzzer started going off. Mind you i checked at the house to make sure the water was coming out up near the head. so i called it off and as he was backing up to get a run at the trailer reverse quit working we got luck and it drifted right up on the trailer.
So i been reading these forums and everyone says to change the lower unit oil for normal maintence i went ahead and did that and the oil that came out was BLACK and had a little water. It may of got in when we took it out cause it didnt look rusty.
I put some new plugs in for good measure.
I put the muffs on and started it up and now i dont have any water out by the head and reverse doesnt work...
Any clues?
FYI my title reads a 88 115 johnson. The numbers are 115etl730 serial#j4981848
Any clues?
