Boatist
- Joined
- Apr 22, 2002
- 4,552
Re: what do I need to know running 2 fish finders?
Check the frequency ask questions at Lowrance in the 21 to 40 range.
http://www.lowrance.com/en/Support/Frequently-Asked-Questions/
Can I run two sonar units at the same time? (Sonar PA)
A: If both transducers are using the same frequency, they will most likely interfere with each other eventually. You can shut one off or use a switchbox. In shallow water, they may work if the transducers are far enough apart.
Garmin say the same thing only they say if useing the same frequency or near the same frequency they will interfeer. Sorry I could not find a way to capture their whole message but it is not hard to find under support then FAQ (frequency ask questions)
