What do you do to your boat to prepare it for the hurricane ?
NESAR
I have a 20' starcraft Irene is on her way what do I need to do?
Strap it to the trailer?:redface:
25thmustang
Re: What do you do to your boat to prepare it for the hurricane ?
I have heard a lot of things. Marinas down by the shore are in a mad dash to get boats on land. MY place hasn't gone crazy with removing them, but I will be there 8am tomorrow, in case they decide to take everyone out.
A small trailer boat, I would be looking for some kind of storage, or keeping it on my property to keep an eye on it.
Friscoboater
I feel for you guys on the east coast. This is a rare event.
Home Cookin'
there are a million possible choices, driven by a million variables.
Generally, a boat on a trailer is safer than one in the water or on a lift. Most likely, your 20' should be on a trailer, parked on high ground, and away from other boats on trailers that may blow around. Tie it to the trailer like you would for travel. Remove all loose objects, cover (most of the time but not all), bimini, etc. Lower the tongue jack to trap water and add weight. Adding water, plug in, is debatable.
If you leave it in the water, account for these things:
tide 8' higher than normal OR Tide 6' lower than usual. If it does both, you're usually screwed.
Big waves so be mindful of the stern getting overwash.
Torrential rain than may overwhelm the bilge pump if your boat is not self-bailing. In fact, I'd sau if it's not self bailing, don't risk everything on the frail pump, its wiring and battery; pull out.
Your boat banging against pilings
Your boat landing on top of a piling that is shorter than the 8' tide.
Most likely problem--the guy next to you not tying properly.
Not that you can do anything, but in storms around here, boats tied 100% correctly to a floating dock were lost when the whole dock floated away--one with several boats on it!
You may be better off anchored out than moored to a pier or piling.
On the lift: tie it down but account for the 8" tide.
So some of these factors won't matter if you are in a gunk hole, or sheltered from the worst wind (in this respect a northeaster is easy and a hurricane not. I have lived through many, and seen storms of equivalent strength put 4' waves on one side of the creek and nothing on the other side 1000 yards away; the other storm it was the other way around.)
TBGixxer
I have my boat trailered on the side of my house. Great idea bout letting the water build up to add weight to the boat. Sounds logical but I would not have thought of that.
scipper77
Move it inland would be about the simplest thing. There is not much you can do to fight nature. If you feel the winds will not be sufficient to damage the house maybe park it on the north side of the house. Be aware of any trees that may damage the boat if they fall.
While we are at it now is a good time to survey your property for potential tree damage of other things like power lines, sheds, cars. I just decided to move mt third car out from under the trees, just in case a branch falls. Also I should move our garbage tote into the garage so I wont have to track that down later.
Where I am in NY we won't see winds like you will and I'm pretty nervous. Good luck and remember to be safe first and foremost.
EddiePetty
No useful information to follow, just a story about a hurricane of my youth in Richmond, Va. that was previously posted on Richmond City Watch a few years ago.
And for the youngsters in the crowd, hurricane Hazel was in 1954!!
My Grandfather and Dad joint-owned a 25 ft., solid wood cabin cruiser, docked in Sara?s Creek (Gloucester Point). Granddad had died in the preceding August, and Dad could not afford the slip rental and upkeep on his sole income as a draftsman for the City of Richmond (in ?The Aluminum Building? even). Using some of that aforementioned determination (and lack of funds), Dad set out to haul that heavy boat back to Richmond using a bumper hitch on his ?49 Mercury straight stick! Progress was good along US 360 (the speed limit was 40 then, on just a two-lane road) until that poor old Mercury encountered the grade East of Pesley Farm. The clutch didn?t have enough left in it to pull all the weight. A long-boom wrecker, with boat dolly and trailer, was dispatched from Coleman Scales (W. Broad Street) to fetch the boat to Fairmount. Granddad had owned most of the 1700 block of N. 23rd Street back then, thus the boat was deposited atop 55 gallon drums in my Grandmother?s side yard??Along comes Hurricane Hazel!! Dad, Mom, Granny, my baby sister and I toted rocks, bricks and anything of weight to anchor that boat . Dad tied the bow to a pair of cherry trees and the stern to a giant apple tree. Hazel had her way with Richmond: howling wind, driving rain, pelting hail and blinding lightening for what seemed to be days (at least to this, then, six year old mind). After the storm had passed, the shutters un-latched and the ?All Clear? sounded from the neighborhood Civil Defense siren, the damaged was surveyed. There the boat sat: high and dry atop its 55 gallon drum perch, however, the cherry trees were completely uprooted and having not been secured to the boat they would surely have been blown away !!
LongLine
If you can't haul it safely inland, take a whole bunch of pictures & upload to photobucket or someplace. You may need it for insurance. I hope it goes out to sea. Good luck.
