rickasbury
Master Chief Petty Officer
Thread starter- Joined
- Jul 13, 2011
- 878
So, probably not the right section for the question but I figure this an issue for I/O owners for the most part. After buying my boat about 4 years ago (Rinker 270) and with no service history and a PO that I would not really trust to tell me anything I did not want to hear, I was very worried about bellows and the boat sinking. Then, after getting familiar with it and inspecting it regularly I was not as concerned about it although it was on my list of stuff to do- which has now been done. Also, transom asy was completely removed with a leak around that main seal and I wanted to inspect the transom and fix that leak which now all is done. I had dunked it in the water at the ramp prior to re installing the engine to make sure my leak was fixed and as far as I know it is. Not to derail this thread, I don't think a lot about the engineering of how the bellows and shift cable attach. Sure looks like something that easily could go wrong when you consider that about every other hose on the boat is double clamped yet we have the whole fate of the boating hanging on a rubber bellows that gets pulled back and forth, it has a clamp on it with some adhesive. I don't understand why they can't cast some kind of lip or indent where the clamp goes so it can't slide off. When I first dunked the boat in the above test it was leaking- when I put the out drive back on it must have gone up to far and the shift cable boot started to come off and it was leaking. Re attached and all seemed to be good. Anyway, back to my question...so now that I have "fixed" everything, I'm back to being concerned that something can go wrong and the boat sink. I"m putting it in the water tomorrow at my local city marina to spend the night to hopefully have a "dry run" of being back in the water and checking to make sure it is indeed fixed. But, assuming it is fixed, you could always have a below water line hose that ruptures or something that water is coming in and the pump can't keep up with. So, in the event of something like this happening, what do you do? Seatow? What if it is in the middle of the night? Does the marina typically have an emergency number to call with a handy pump??
