What does catalist assemby do
danny9696
Hi all I just bought a yamaha waverunner 2001 XLT 1200 but I was told it needs a catalist assembly, not sure what it is or what it does and can it be repaired.
When I bought it, the head was cracked, needed a piston and a catalist assembly, what would take out these items, this is my first PWC and need to learn fast about them so I do not mess it up
Thank you
Dany
Ernest T
Re: What does catalist assemby do
Probably talking about the catalytic converter. Works just like the one on your car to reduce 2 stroke emissions. Problem is that on the Yamaha skis, the cat/con tends to fail and actually break apart over time and actually fall into the exhaust system and cause problems.
Rather than replace it, most owners recommend installing a plate called a D-Plate. The ski will run better and you never have to worry about it failing and causing serious problems. http://www.rivayamaha.com/RivaStore/product_page.asp?Category=Cat Removal D Plate You will also want to get the chip that will prevent your system from giving you an alarm or warning about the exhaust temp.
Parts for a top end rebuild can be found here: http://www.shopsbt.com/
