jbjennings
- Joined
- Jul 18, 2007
- 3,903
I'm rebuilding my merc 650 3-cylinder and can't figure out how this part (#3 in the diagram--retaining ring) works, or it's sequence in the poppet valve assembly. THis motor didn't have a thermostat or the popppet assembly installed when I got it. The "retaining ring" looks like a tab washer, but I can't see what it retains or what role it plays. The parts diagram has the parts in the poppet assembly out of order in the picture. The spring should go on the stem of the poppet and be held on the other end by the baffle plate, right? then above the baffle plate, I screw the plastic washer down on the diaphragm and throught the stem of the poppet valve, right?
Anyway, any assistance on this poppet valve assembly would be super helpful. I have no idea where the "retaining righ" goes. Here's a link to the parts diagram I'm looking at.
Mercury, Mercruiser, Force, etc. - CYLINDER BLOCK AND CRANKCASE COMPONENTS - MERC 650 (3 CYLINDER)
Also, any insight on the cooling system as far as if it has any service bulletins would be greatly appreciated.
Thanks,
JBJennings
Thanks,
JBJennings
