I see a lot of info about changing water impellers on a fairly regular basis on Alpha 1 outdrives. I see only a few recommendations about changing out the shift shaft seal or oil seals under the water pump at the same time, but these few people highly suggest that these seals should definitely be changed for good measure.
Most of you have way more knowledge and experience than me, so I'd like your opinion.
What else do you change in your outdrive when you change impellers?
Thanks
Thanks
