Re: what filter do i use?? 1990 2.3 omc cobra
Welcomt to iboats.<br /><br />That's a Ford motor, so any filter to fit a 1990 2.3L Ford will work.<br /><br />I assume you're referring to the gearcase plugs? They either have gaskets or O-rings. You can just replace those. Be aware that you have an upper and a lower gearcase that are connected. If you drain the lower half, you also drain the upper half. Fill from the bottom until it reads on the dipstick in the top. But there's also a plug on the side where the upper and lower meet. That should be removed until lube spills out, plugged, then continue filling. A lot of people forget the "continue filling" part and cook the upper.
