what gasket do i need? please help
Bass_fisher
I am going to be changing the oil on my 1983 15hp johnson and im not sure what gaskets i need for the drain and vent plug. i assume their the same, but what plug do i need to replace them with. thanks
Daviet
Re: what gasket do i need? please help
Qty 2--0311598 washer.
Bob_VT
The lower unit oil?
They (both plugs) use the same plastic O ring gasket...... they can be re-used as long as they are not chewed up and leaking. They are hard plastic o rings.
Bass_fisher
Can i pick these up at a local marina or a westmarine store? i want to get them local so i can use it thursday thru the weekend.
Vic.S
According to the parts diagram in the PARTS CATALOG both drain and level screws are the same and fitted with the usual flat nylon wshers. # 11 in the gearcase diagram.
Be aware though that sometimes O rings turn up! If the screws fitted should have O rings the there will be recesses for them on the underside of the head. The screws that take the flat washers are flat under the heads.
Take care to only undo the two identical broad headed and slotted screws. The smaller screw next to the drain screw holds some of the insides in position. Undo it and it'll all fall apart inside :mad:
Sometimes the nylon washers come out with the screws and sometimes they stay in the hole. Take care to remove the old washers before fitting new ones.
