What gearcase lubricant should be used on Johnson and Evinrude Motors?
iboat2011
Hello,
I have one Johnson 1962 40hp and one Evinrude 1968 18hp motor and both are manual shift. The manual mentions OMC Type C lubricant for the lower unit's gearcase. However it is hard to find nowadays. I am just wondering if Pennzoil Marine 80W90 Gear Lube found in Wal-Mart can be used instead? If not, what other brands can be used?
Thanks a lot in advance!
Andrew
hidef
Re: What gearcase lubricant should be used on Johnson and Evinrude Motors?
The Pennzoil will work just fine.
rickdb1boat
The Pennzoil Marine 80W90 Gear Lube will work fine.
iboat2011
Thanks a lot for the replies!
I just went to a Super Walmart. All they have is QuickSilver Marine Gearcase Lube. I am wondering if it is ok for my motors?
Thanks,
Andrew
hidef
As long as it is either 80W90 or 90w it is fine. The Quicksilver gear lube is good.
Chris1956
Type C is for electric shift motors only. Any marine gearlube for mechanical shift motors is fine.
seahorse5
Hello,
Andrew
Type C is now called Premium Blend and is only recommended for the electic shift and electro-hydraulic shift motors.
For your "oldies" a marine 90 will work or you can use the newere Evinrude gear oils such as HPF-XR and HPF-Pro.
