- Joined
- Mar 8, 2009
- 43,318
Talking about my Formula with the 502. Originally had a MEFI-1 and a direct connection (tan/Blue) from the warning horn (beeper) to the Temp and oil pressure switches and the drive lube bottle. When switch closed the horn would sound.
Today, up graded to the MEFI-3 and now all these same switches, Drive lube (Tan/Wht), Oil pressure (BK Blue) and Water Temp (Yel) go to the computer. There is another Tan/Wht wire which connects to the Tan/Blu wire on the engine harness connector. This connector on the wiring diagram shows 5 terminals, mine has 2 smaller connectors.
Issue: when the key is turned to on the fuel pump runs for a few seconds, the normal two beep signal is not heard. No beeps or other sounds are heard. With the engine running at idle, I have grounded the lube bottle terminal and the temp sender wire one at a time. No warning horn/beeper is heard. Put my scanner on the engine and no codes. Not seeing codes would be normal for the MEFI-3 per the sheet I have.
I'm looking for a connection between the switches and the Tan/Blu wire via the Tan/Wht wire coming from the ECM
Also on other motors I have heard the startup beeps come from the engine and not the horn under the helm. Is there a beeper mounted on the engine?
