What have I done? Gear oil leaking out before level reaches vent hole
idflyfisher
I changed the impeller and when I was refilling the gear oil it is leaking out a hole where normally water drains just below where the upper and lower units join???? HELP. Did I damage something?
dpoff
Re: What have I done? Gear oil leaking out before level reaches vent hole
Forgot to put the O-ring in the oil passage where the two halves of the outdrive mate?
The quad ring gasket may have moved outta place or altogether.
idflyfisher
thanks for the replies. I was not even aware there was a seal there?? I will have to look. That seems to be where it is leaking from. At least that side according to the exploded view of the lower unit I just looked at.
Depending on what imepller kit you picked up... the new Quad ring is part of the kit, as well as new gaskets on the drain and vent plugs.
ktbarrentine
Did you omit doing a pressure test when you reassembled the drive?
