What hp kicker motor do i need ?
lawrence101
I have a 75hp main outboard engine on a 16' boat weighing approx. 1600 pounds, what size auxiliary motor would be sufficient ? The reason im asking is that im to meet someone tomorrow afternoon that's selling a 9.9 hp ( only 10 hours on the motor! ). But im not sure if the motor is powerful enough for my needs.
GA_Boater
9.9 is more than enough for trolling and it will get you home if the big motor breaks. Not fast, but it'll do it.
dan t.
Yep, a 9.9 is just about over kill for a 16 footer. I had a 16 ft Sangster with an 80 Merc and a 4.5 kicker, it was plenty for trolling and got me home from 9 miles out one time the 80 died from electrical problems.
littlerayray
I'm assuming that the boat your buying the kicker for is in your avatar good luck have fun
Pony
9.9 is perfect.....not that you needed any more confirmation ;)
airshot
More than enough HP for your boat.....my concern would be the additional weight. Even if it is a two stroke, another 75lb on the transom along with your main motor might be a bit much. Then again you couls sell the 9.9 and get a smaller motor if the 9.9 is priced right. A small two stroke 4 hp or 5 would be plenty. I use a 9.9 on my 22' cuddy and it has plenty of power. Can get more than 10 mph out of it in an emergency.
Teamster
Whatever you buy, Get a two cylinder,....The vibrations of a single will drive ya nuts,...........
NYBo
Just so you know, if the HP of your main motor plus the kicker exceeds the rated capacity, you are technically overpowered.
smokeonthewater
Only if they are running at the same time.
Personally I think a 9.9 is a bit much (heavy) for that boat... Would be looking for 5 hp myself.
fishin98
On my 2000 Bayliner 1802 Capri Cuddy...I had a 2007 Merc 5hp 4str long shaft kicker hanging on the back.It moved the boat quite well.
Fleetwin
A general rule I've always followed is: 10% of your main engine HP. In your case, 7.5.
Pony
Sort of difficult to say for sure without better specs on the boat. I have fished a lot out of a 16ft alumacraft dominator that had a 75hp main and a 9.9 kicker. Was absolutely fine and wasn't too heavy.
I have also fished in 16 footers whet I wouldn't dream of using a 9.9 as a kicker.
Pony
Im not sure that once you get above 100hp that would make much sense. All those tournament walleye boats with 250/300 hp would have 25/35hp kickers.
In this case it works....but I'd still want the 9.9. Where I troll I would want the extra power if I needed to use it to get back to the launch in 3-4 footers for a 5-10 mile stretch
ondarvr
Not true. And that is actual CG policy. Strange, I admit.
The CG has nothing to say about it, it would be a local regulation. The CG just makes recommendations, they don't regulate it.
NYBo
Actually, they do. They can enforce it and terminate a voyage immediately on the basis of being overpowered. Not likely to happen, though. You also can't pass a vessel safety check, if that's important to you.
