what I need to paint my boat HELP with my project!!!
betayv
hi there again to everybody on this forum I need some help with my project, my 1979 barnegat I want to change the color to give a better look so I will need full ideas to learn, like If I need to sand all the boat before I paint, what type of sand paper, what type of primer Im sorry If I have many questions but I want to learn and change the look of my boat thanks.
LX Kid
Ensign
Re: what I need to paint my boat HELP with my project!!!
Here's a list of the things I'm using for my paint job. My painting job was for "above the water line" and so your paint will be differant from what I used. I used Rust-Oleum "Marine Topside" for everything except the hull, which I did'nt paint.
1. Orbital sander (Mine is electric and have to be carefull around wet sanding (NOT SAFE!!!). If you have a compressor a random/orbital air sander is best.)
2. 220 Wet/Dry sandpaper
3. Paint stir sticks (Use with sandpaper wrapped around for long edge sanding)
4. Acetone/Mineral spirits (For wipe down prior to painting/clean-up)
5. Heat paint stripping gun (Used it on low setting to remove decals & strips)
6. 4" closed foam paint rollers. (Don't clean them when done, toss them out)
7. Buffer for final compounding and polishing.
Do a lot of reading on the subject from links and books to get an idea of how to procede. I'm no professional but these are the items I'm using and is working out for me. Good luck, Ron
betayv
hey thanks is a good start so I going to get some of the stuff you mention LX thanks again I will keep you posting about how is going.
erikgreen
Prep, prep, and more prep. It's the most important part of the process. Also be aware that a painted hull can hide repairs and problems, and many boat buyers are aware of this. If your hull isn't already painted, you might be decreasing your resale value by covering perfectly good glass.
Here's an interesting thing to do for estimating your prep time:
Go to the lumberyard and buy a small piece of rough sawn quality wood... something hard like ash or oak. Get it rough, not sanded.
Using your sanding tools as described above, and grades of sandpaper from about 120 through 220, and then 400 to 600, spend time sanding the wood until the surface is as perfect as you can make it... smooth and flat.
Then using a sample of the primer you'd use for the boat, paint it. Examine it afterward for high spots, bumps, cracks, etc and sand with fine grit as needed.
Then apply the actual paint, using the roll and tip method or similar to get a smooth, evenly flowed surface.
Finally examine it... with a good quality paint, you should now have a surface that is smooth, shiny, and will reflect light with a sparkle.
If it doesn't look smooth, like there are bumps, the grain shows through, the surface is uneven, or has scratch marks, you didn't sand enough.
If it looks good, multiply the time it took to get that smooth surface by the size of your boat.
You should find that the time you'll spend sanding and cleaning your hull in prep for painting will be about 95 percent of the time you spend on this project. If you spend half the time prepping and half painting, you'll almost certainly end up with a lousy result that looks worse than what you have
now.
Either way, you'll get a fair appreciation for why boat manufacturers typically like to pull a smooth hull from the mold rather than trying to fair it afterward :)
Erik
PS: You can also look in Oops! thread on hull extension to find out how much time he spend sanding his new gelcoat fair.
