fisherman67
Thread starter- Joined
- Jan 27, 2011
- 11
I have had a nightmare of a time trying to get this motor to idle correctly without having to constantly push in on the choke. I have taken the carbs apart three times to make sure all small passages are clear, the last I even stuck a small piece of wire thru the passages to make sure there are no restrictions, but I did notice the idle orffice jet had 33 stamped on it and when I looked up what size oriffice should be in this motor it says it should have 36 jet. Could this small difference in sizes be causing the motor not to idle right?
