What is leaking behind the prop?
chattyrona
If the motor is leaking from behind where the prop is attached what exactly is that seal or gasket called if I have to ask for a replacement?
jtexas
Re: What is leaking behind the prop?
propshaft seal.
but it might just be unburned engine oil dripping from the exhaust.
if your propshaft seal is compromised, you'll find water in the gear oil.
tashasdaddy
prop shaft seal, she has a 57 35hp. should come in sierra kit # 182686.
chattyrona
Thank you for the info. It is appreciated!
samo_ott
TD, how do you get all these Sierra numbers? Do you have a guide or is there a website?
18/20/25 1958-78 2684 19.95 equals 18-2684
