mtduckhunter
- Joined
- Jan 31, 2008
- 241
what does porpoising and cavitation mean? im thinking about getting a hydrofoil and it says they eliminate this.
that, i think is ventilation. cavitation is when water boils and turns into steam, then goes back to water form. when this occurs, the water drops actually hammer on the prop and eat chuncks out of it....Cavitation is when the prop starts turning in air.
Or like a porpoisePorpoising is when the bow starts bounching up and down like a dolphin
There is a reason that Boatist and I always mention this . . .Helm adjustable tabs if you want complete control of your boat in all conditions and speeds.
the reason i asked is because my boats front end is riding in the water when on plane. i was told it could have hook but i looked and it didnt seem to have. i can tell that the boat is being slowed down by this. how can i fix this?
The function of a prop is to create an area of low pressure that the blade is then sucked into. Near the blade tips the pressure is very low compared to the surrounding water. This ultra low pressure is essentially pulling on the water molecules. The tensile strength (force holding the molecules together) of the water is the vapor pressure. This means that if you prop is turning too fast you are creating a pressure that is lower than the vapor pressure of the water. The water molecules are being pulled apart and steam is filling the gaps between the molecules. When this steam bubble passes to the back side of the blade, the water pressure is much higher and the bubble is smashed and the steam condense. This is a very very violent action that releases quite a bit of energy. That energy is what pits the prop blade.
There are some formulas to check for cavitation but I can not recall them off the top of my head.
