What is the best fuel to run in a 68 Mercrusier 120 hp
Spivy30
I just bought a 68 starcraft holiday with a 120hp mercruiser and was wondering what would be the best fuel octane to run it. The boat sat for a few years but was fogged I had it running the other day but it would stay running under 3000 rpms and it was back firing every now and then. I put about 2 gallons of 87 oct pump gas in it before I can it and guy told me the fuel might not have enough octane. I was thinking it might be a timming problem too.
Re: What is the best fuel to run in a 68 Mercrusier 120 hp
The fact that it was backfiring has nothing to do with 87 octane. There is something else going on here.
Also if your are running on muffs 3000 is not a good idea.
Spivy30
I'm thinking it has something to do with the timing and the points. I bought a tune up kit for the ignition with a cap rotor points ect. When you set the timing should it be at idle? Around 500-700 rpms? Thanks again you helped with me someother stuff too I apperciate it a lot.
Fishermark
Yep - just good old regular unleaded works fine on that engine.
Yes - the timing should be set at idle. Set your point gap / dwell first, then the timing.
bigskiohio
Master Chief Petty Officer
i run the highest octane i can get makes me feel better as my 120 sips the fuel it doesnt bother me to pay 20 cents more per gallon.
I just did my points and my boat ran great before and it ran better after the new points. dwell was a little tough to set. actually th timing should not change it only changes as points wear and dwell changes. so dwell is more important of the two but check anyways.
dozerII
I`m with you Bigsky, I burn premium as well, in my 72 SS 120 that is what the manual calls for and with the little bit it uses what the heck.
Glen
dubs283
premium, non-oxygenated fuel is what you want to run in your boat
no ethanol/alcohol at all
check out some of the how to's in the DIY section at the top of the threads page
a wealth of information there
sethjon
The 20 cents isn't the issue. It doesn't make the engine run any better or faster or smoother or anything else you can think of. 87 is more than enough.
bigskiohio
Like i said makes me feel better and i cant prove but i am sure it helps it from having any preigniton problems .
dubs283
octane = resistance to burn, some say resistance to knock (AKI = anti-knock index)
the higher the octane, the cooler and slower the fuel/air mixture burns in the combustion chamber
less octane = greater chance for detonation (explosions that destroy pistons)
also, alcohol/ethanol ladened fuels will increase chances for vapor lock
use non-oxy, premiuim fuel in your boat, 92 octane
Spivy30
I gave the boat a tune up and set the timing and it runs perfect and starts right up its amazing what new points and condensor will do. I was just curious about the fuel because it was so old I will try and run nonreformulated fuel but its hard to find in the Milwaukee area you have to go way west out in the county to find it.
Fishermark
The older an engine gets, the more it loses compression. The more it loses compression, the less octane requirement it needs. If you engine runs good on regular, which I suspect it will, then that is all you need. Period. Higher octane will not give you more power or more cleaning agents, or anything else.
HT32BSX115
Absolutely true!
But anything that makes you feel better is good for you I guess....:rolleyes: It's that placebo effect.......
I run the cheapest regular with what ever is inside. It doesn't make any difference.
No gasoline will fix your engine if it's missing, popping, farding, back or front-firing etc!!
With an engine that old, I would do a compression or leak-down check and carefully check the ignition, timing and carb......
regards,
Rick
Brewman61
Ensign
Another thing that can happen to older engines is carbon deposits in the cumbustion chambers. They can act as hot spots, prematurely igniting the fuel, and can also take up enough volume to change the compression, and in those instances, higher octane fuel might work a tinge better.
Essentially masking the problem. I've run many a can of GM top cleaner thru some of my older vehicles- stuff worked pretty well IIRC.
I've pulled the heads off some really nasty carbon fouled engines. Not marine, in this case, but I would think they could be subject to it as well.
Spivy30
I did a compression check and it was 130 across the board. Once I did the tune up the engine started running perfect. I was really wondering about the best fuel because most marinas only sell 89 octane.
