Hello all
I was wondering what the difference of a Chevy 305 block in a car and a 305 block in a boat is there a difference or can I use a block out of a car to replace my cracked block in my boat thanks mike
Casting # is on the block driver's side top next to where the trans. bolts on. Would add the marine motor has a stainless steel top ring.We're do I find this castin number can I find it with the motor still in the boat
Ok thanks so let's say I want to rebuild it right from the piston up with all new gaskets and lot of part from the motor in the boat now I basically want to start from scratch with the block
And bondo what do you mean block castin thanks
What about the camshaft profile?
You keep saying truck block wouldn't a 350 from a car be the same thing or for some reason are they different
Just make sure you have brass core plugs (they are not freeze plugs. They are from the casting process, nothing to do with freezing) and that there are tapped holes in the block for the starter-motor to mount to. Most car engines have the starter-motor mounted to the gearbox bell housing, and a lot of car blocks don't have the starter-motor mounting points drilled and tapped.
Chris.......
I haven't seen a small block Chevy yet without the starter holes tapped in the block.
