what is the purpose opf this monster hitch piece??
bob johnson
i picked it up at a marina where I bought the left over inventory....its huge....
I am wondering whats its purpose????
just talking the hitch piece...not the coupler
thanks
bob
southkogs
Re: what is the purpose opf this monster hitch piece??
Sway bars for a travel trailer? That's a shin buster for sure.
H20Rat
That is a typical equalizer hitch setup... very common for travel trailers. Here is a pic of the rest of it.
flycaster
equalizer hitch, could also go by the above mentioned sway bars.
There are two arms with chains attached that are missing
Frank Acampora
And the coupler is a brake unit. When you apply brakes in the tow vehicle, the forward motion of the trailer applies the trailer brakes. The pin is a lock-out so you can back up the trailer. It may also be a dead man so the trailer brakes are automatically applied if the coupler becomes detached from the to vehicle.
kmarine
An equalizer hitch or weight distributing hitch is to a system of leaf like springs to compensatre for a heavy tounge weight. This also adds rigidity to keep wind shear from highway trucks from pushing large trailers off the road with the turbulance made from large trucks.
Silvertip
Not entirely true. Those are called spring bars and have little to do with anti-sway control and everything to do with transferring tongue weight between the front of the tow vehicle and the trailer axles. Think of it as adding wheel barrow handles to the rear of the tow vehicle. Lifting the handles removes weight from the rear of the vehicle and transfers some of it to the front. In application, the ends of the spring bars attach to the trailer frame so that weight goes to the trailer axles. It is all about geometry. Equalizer setups are available with an additional anti-sway feature built in. These are typically an adjustable friction device that must also pivot as turns are made. One of the hitch manufactures demonstrated this concept in 1965 by removing the rear wheels from a front drive Olds Toronado and towed a travel trailer. Tension is adjusted by varying the length of the chains on the snap up brackets. Lastly, wind off the nose of a semi does not push the trailer off the road. In fact the bow wake off the semi pushes the rear end of the trailer to the right which pivots the tongue of the trailer to the left. At the same time the rear of the tow vehicle tends to push left which pivots the nose of the tow vehicle toward the ditch. When that goes on, the inexperienced driver overreacts and sway sets in and it gets worse with each over-correction. An experienced driver will see the semi coming and be ready for the movement. A simple touch on the manual trailer brake control is all that is required to snap the rig straight should excessive movement occur..
Atlas83
I have to agree 100% I pull a 32 ft camper/toy hauler, and with out the Load levelers (is what I call it) you can really tell. anything over 22 feet I would prefer to have them.
ricohman
Not really.
By using this types of hitch I can put weight on my front axle. I use the local weigh scales to confirm this when I set up my car hauler and new truck. It does help with sway when the tounge weight is getting near 1000lbs.
rbh
Defenetly (for me) it is the amount of sway it takes out of the equation when going down the hwy.
Lots of wind and buffeting when the big rigs go by.
