Re: What is the range of Cylinder Compression
There is no "number". Most gasoline engines will run if compression is over 60 psig. Usually, with larger motors one expects ~ 90 to 150 psig and readings should not vary more than ~ 10% between cylinders.<br /><br />Shop manuals do not normally specify any reading.
