What is the recommended idle speed and wot speed for 5.7GSPLKD?
oneboat
Hi everybody
i tried without success to find this info in the library .( if you can point me to the info would be great )
97 Vp 5.7GSPLKD with Holley 4bbl .
What would be recommended idle speed for it ?
for wot i found to be about 4500 rpm on various posts
Thanks
Fun Times
Without not being able to quickly locate your exact RPM spec within the Volvo service manual, an idea to help locate the idle RPM spec from Volvo on your engine may be available right on the engine itself...If it's still there and legible, there typically is a sticker on the engine that should offer the RPM idle speed...As sort of seen in the image below on the left front electrical box...Yours may be in a slightly different area if not there as seen.
When looking up your engine I ran across the "initial idle mixture setting" spec which says 3/4 to 1 turn of seated position.
That mentioned, idle RPM usually averages 600 - 650.
http://i.ebayimg.com/images/i/231836...-1/s-l1000.jpg
