Re: What is the trick for getting the lower unit onto motor of 1989 35hp Merc
I'm thinkin' the exhaust tube rubber seal should be firmly positioned into the gearcase and not placed on the end of the exhaust tube. Although it may have come out on the end of the tube.
Typically it'd be in the lower unit with the exhaust tube coming down to meet. I can imagine that if it's on the end of the exhaust tube, that's gonna keep things from seating properly.
Other tip, shift both gearbox and lower unit to Neutral. The shift shaft on your 35hp rotates CCW from Fwd to Neutral to Rev. There should be about 270 deg of free motion on the shift shaft when the L/U is in Fwd. But as soon as you rotate CCW you'll reach a point of resistance. Further rotation CCW shifts into Neutral.
If you do need to manually shift the L/U, be sure to wrap some tape around, or otherwise cushion, the jaws of pliers or Vise Grips etc, used to move the shift shaft. Otherwise you could mar the splines on the shift shaft, making installation even more difficult!
Now, sometimes the doggone shaft splines just don't wanna line up regardless of what you do, in that case you may have to disconnect the shift cable from the shifter arm, up in the powerhead. Then you can "jiggle" the shifter arm to and fro a few degrees to line up the shift shaft.
Just be sure to note the approximate position of the upper shift arm, when in Neutral, before you disconnect the shift cable. Then you'll have a good idea where it should be when you reinstall the L/U.
Shine a light into the 'gap' between L/U and exhaust tower, when you're inserting the L/U. You'll be able to sight the water tube entering the pump; at about the same time, the driveshaft's gonna wanna engage, and you'll need to turn the flywheel a few degrees to align crankshaft and driveshaft splines.
BE SURE SPARK PLUGS WIRES ARE PULLED before turning the flywheel! :0
Very shortly thereafter comes the shift shaft, and the exhaust tube usually brings up the rear! It does help if you grease up the I.D. of the rubber gasket, and the O.D. of the exhaust tube.
Note if the rubber gasket is torn on the inside, or warped inwards, the exhaust tube will catch on the gasket instead of slipping into place. In that case it's best to renew the gasket. Or, completely clean and degrease both gasket and L/U where the gasket sits, and use some contact cement to hold the gasket in position.
That should just about do it, you oughter have that L/U back on in 10 minutes or less!!!!
HTH.......ed
