What is the water line size on a 2002 chaparral 265ssi ???
amanphoto
What is the water line size on a 2002 chaparral 265ssi? I want to add a transom shower to my friends boat, but not sure what size pipe to get? Any ideas?
Thanks
cr2k
Re: What is the water line size on a 2002 chaparral 265ssi ???
Look at the water line and determine. You gave us no information that would help determine that since it could have one several different drive packages.
captain zac
I have a 2001 265
It has standard fresh water supply you can get on this sight
I have a small recessed tramsom shower Recessed Shower Handle, 45 Degree - Scandvik Part # 11750
The tubing is 38 inch with the quick disconect fittings
should not need much my shower is on the port side and the water pump and tank is there also
Harry
