What is the year of my Outboard Mercury Engine?
ohdannyboy
I have a Mercury Outboard that is 4 cylinder with a Model 4D-3 Magneto Type. The sticker on the engine says it's 65Hp Thunderbolt. I can't be sure if the previous owner put these stickers on because the front plate is blue and shows Mercury 500 but the cowling is a wrap around with red stripes. The sticker on the side is in red stripes and has 65HP. Anyhow, the engine was mounted on a 1965 Sportilne 16ft boat. I need to know the year of the engine. These are the numbers I found.
1. Under the flywheel on the engine ( 1128-1890)
2. The right side of the engine block looking from the back of the boat (Kiethaelfer Panther 834-1851)
3. On the engine block where the spark plugs are at ( 1012-2077)
4. Left motor bracket ( 1440-1333) same bracket just further back ( HA2014-111)
Which number do I use as reference? Thanks in advance.
WaveJumpingMaxum
Re: What is the year of my Outboard Mercury Engine?
Can you post pictures of it? ,My cousin has a similar sounding engine its a 79, i i think its 70s-80s prob 77 the last two numbers on the block.
ohdannyboy
I will post a picture tomorrow. Is there another area I should be looking for the serial number? After doing some research its seemed to me that it was circa 65, 66, 67 year only because that's the time that the Magneto was used. After 67 a distributor was used. I don't know? Will post a picture tomorrow. Thanks
ohdannyboy
Thanks for your response. I will post some pictures tomorrow.
ohdannyboy
ohdannyboy
Here are my pics...hope it will give an idea to find out the year of my Mercury OB. I looked everywhere for the serial number and the only ones I found so far are the ones listed in my first post.
ohdannyboy
Still haven't been able to find serial number but the title for.the boat says its a 1964 Sportline so the engine is either a 64 or 65. I will go with this for now.
