flatiron14
Thread starter- Joined
- May 10, 2009
- 26
Instead of rebuilding the old one, which had some wear and the bowls were kinda gunky, I decided to replace my Edelbrock 1409 carb on my '92 Merc 305. Everything seems to line up and function fine, however, when I got the motor running, I could hear a hissing and found this hole in the front of the carb that was drawing a lot of air. I looked in the manual and found this is the PCV valve inlet on some carbs? Is it supposed to be drilled in my marine carb? Also, when I plug this hole with my finger it brings the rpms down and at idle it can stall the motor. What do I need to do here?
I attatched an image of where this inlet is on my carb.
