MotorMan101
Thread starter- Joined
- Sep 28, 2022
- 73
It's from a bow rider I'm holding it the same way it was mounted... The boat is equipped within 110 horse outboard.what kind of boat and what type engine and drive. The first thing that comes to mind is a tilt and trim gauge. Second if you are holding it 90 degrees off it may be a rudder position indicator.
That rules out my guess #2. More than likely tilt and trim gauge. Did you try tilting the engine up and down when it was connected to see if it would move. The sending units for those if that is what it is are more often the cause of it not working than the gauge itself.It's from a bow rider I'm holding it the same way it was mounted... The boat is equipped within 110 horse outboard.
Wow....havent saw a rudder indicator gage in many many moons !! Were popular in old boats when I was a kid !!what kind of boat and what type engine and drive. The first thing that comes to mind is a tilt and trim gauge. Second if you are holding it 90 degrees off it may be a rudder position indicator.
Looks like an OMC Gauge for Trimwhat kind of boat and what type engine and drive. The first thing that comes to mind is a tilt and trim gauge. Second if you are holding it 90 degrees off it may be a rudder position indicator.
