What is this part / hose and can I reuse it?
toy4x4
Ok so I am in the process of replacing my gimball bearing, bellows, water pump, and anything else that might be questionable. I pulled the lower unit off last night and a small hose was attached. When I tried to pull the hose off of the plastic nipple, the plastic piece came unplugged instead.:eek: Now I am worried that this plastic plug may be a weak point. I see how it plugs back but I don't like the design it looks shoty. Do you think I would be safe to reuse this hose and plastic plug or should I replace them with something better? Where does this line go anyway? What is it for?:confused:
Don S
Re: What is this part / hose and can I reuse it?
It's the speedometer tube.
toy4x4
Oh so I shouldn't be to concerned if it leaks its not going to let water into my sterndrive or oil out then.
Don S
Nope, unhooked the speedometer won't work. That's all.
