What is this piece?
ajkolar
1988 OMC Cobra 5.7. On the starboard side of the intake manifold is (towards the center, under the carb) is a small piece of coiled metal with a cover that is held on by two screws. What is this? I believe I may have damaged mine (which already appeared to be old rusty and not doing anything) when working on the engine. Is this something that needs to be replaced?
newport dave
Re: What is this piece?
Thats your automatic choke thermostat. Your automatic choke will not function or may function improperly if it is damaged. You can get a new one for about ten bucks at most auto parts stores (it is not marine specific).<br /><br />Dave
KaGee
LOOK HERE <br /><br />The part is discontiued by OMC, but like said above, should be available through NAPA.
ajkolar
I thought it might be something like that... However, unless some of mine is missing, I don't understand how this works? It doesn't seem to connect to the carb in any way, and I am sure it isn't doing anything under the manifold? Kagee, Which part number is it on that exploded view from dougrussell.com? I looked there prior to posting but I couldn't seem to pick it out.<br /><br />I am reasonably mechanically inclined, but very carb illiterate! How can I verify if the automatic choke is working while looking at the carb during startup? Sorry for the ignorance. <br /><br />Thank you all for your help!
KaGee
LOOK at part number 28. That is your choke thermostat. as the intake warms, the spring coils up pulling the choke butterfly open wider.
ajkolar
So it looks like part number 25 is the link from the coil to the carb, is that right. If that is the case I must be missing it (never had it when purchased). So if I buy a new choke thermostat from the auto parts store, will they have the linkage to hook it to the carb, or will that have to be purchased from a marine specific supplier? <br /><br />Also, I want to make sure that this piece bolts to the intake manifold, not the carb, right? Thanks!
KaGee
Yes, #25 is the link that connects the coil with the butterfly linkage. Surprised the engine ran warm without it.<br /><br />That carb is similar to the Q-Jet used in auto's. You should be able to locate both at NAPA. You might also check your local Chevy parts house. Have them look up any 88 Chevy with a 4 bbl 5.7.<br /><br />NAPA may want your carb number too. Write it down and take it with you if you can find it.
