After removing my motor from my aluminum boat, I found some corroded aluminum near where the motor mounted. The bolts for the motor are stainless steel and seemed fine and it is possible the the corrosion is from a previous motor that was used on the boat? I did however notice this thick white powdery stuff (no oder to it) and can only imagine that it is salt? I also fear that the plywood that is in the transom is pressure treated but could it cause this?
Looking straight down, you can see that this white creamy powder is between the plywood and the transom plates. Plywood is wet near the top but seems to be in ok shape?
