What is this switch for?
jrmarsh
Hi,
Johnson 115 1982.
Does anyone know what this switch is for and which position it should be in to start or run the motor?
Thank you in advance!
The unit is the primer valve.----It is NOT a pump.-----When you push the key in WHILE cranking the motor this valve opens.-----Fuel is then sprayed directly into the motor for starting.------It works better than choke flappers.----The red lever is for manually opening the valve.----In case you had a dead battery , some motors can be started with a rope if battery is dead.
jrmarsh
Thank you for your response. Which position should it be in when starting the motor using the key and battery?
