what is this .....
coolbikeguy
what is this broken red lever for ? i was told a manual primer or something like that ?? is it used often ? how is it used ??
Daviet
Re: what is this .....
That is the lever that you turn to operate the choke manually.
It has two positions, automatic and manual. If it is not leaking fuel and the engine starts and run properly, don't worry about it.
There are replacement parts available for it, what is your engine model number?
coolbikeguy
idk daviet ..... cant read the numbers on the tag ..... i have another post about that in this forum
schematic
how is it used ??
As Daviet says, its a manual primer lever. It also can come equipped with a shrader valve on the end which will allow you to connect BRP fog or decarb aerosol cans.
coolbikeguy
found out my model # is L90GLAI
