What is this???
Kongfish
Can anyone tell me what this is and what the correct part is that goes here and where it goes to? Or where it connects or what it connects to and with what? I am referring to the little nipple looking thing I am pointing to with my index finger in the photo?
Also I added a second photo, do you where this wire connects to? black/yellow stripe
Honorary Supreme Mariner
Re: What is this???
There should be a terminal on the switch box identified with ---BLK / YEL-------But it does indicate someone tried some ignition trouble shooting.----------New to you motor ?
Re: What is this???
There should be a terminal on the switch box identified with ---BLK / YEL-------But it does indicate someone tried some ignition trouble shooting.----------New to you motor ?-------Can not identify anything in picture one, try better pictures.
Dukedog
Re: What is this???
Does your motor have/had a mercury switch? Black/yellow is part of tha kill circuit.....
Bt Doctur
Re: What is this???
If you tell us what motor and what serial number you might get the manual
carholme
Re: What is this???
I think this is his engine as I dug up the notes for him the other day:
MERCURY - (175 H.P. (1990M ))
Serial No: 0C289990 Model No: 11754220D
I am not even going to waste my time with a manual for those who can't even answer the posts you work for them. They want all the answers but forget the basic courtesies.
Gerry
Kongfish
Re: What is this???
Gerry
Gerry,
help me out here, Don't get all puffed up on me, I've been out working on the motor I've just got in. To check THE forum to see if anyone was able to help me with ID ing some of these wires and hoses
The motor is the right motor you were referring to above. 1990 175 Hp 1175422OD And I have some problems, that above being only one of them. I could use a service manual on my motor big time. Any help on this would be great.
Kongfish
Re: What is this???
I use a iPad 2 the manual uses flash I couldn't open it.
I just bought this motor, it came with the boat so, I am hoping to get it running I have multipule minor issues I need to fix and would greatly appreciate the help.
Kongfish
Re: What is this???
Can you repost the service manual so it will open with a iPad ?
Kongfish
Re: What is this???
I have multiple issues with the motor I need to address if you can help me with them.
Kongfish
Re: What is this???
C289990 is the serial number on the engine block bolt
