Re: what is tow weight?
If your looking to clean up the rust, look into any of several available rust converter products available.
I wouldn't use muriatic acid.
Wire brush the loose rust, paint with rust converter and paint over it.
If it were mine I'd be looking into getting a trailer that sets the boat much lower.
I'd also want a decent amount of extra tongue length. Both features will keep you farther from the water and the slick stuff on the ramp.
How much tow vehicle you need also has a lot to do with how far you tow. If your ride to the boat launch is only a few miles, then its not likely you need a big vehicle. I lived a block away from my most used boat ramp for years, I hauled my boat with what ever vehicle I had at the time. Now that I moved farther away, I bought a truck to pull my boat which goes about 20 miles each way to the ramp.
I had a neighbor who used an early 80's Pontiac Sunbird to tow his ski boat for years, but he only went a 1/4 mile at best to the water each way. When the Sunbird died he used a tractor. He soon found out that tractors don't have the best brakes though and his 23' boat nearly pulled him and the tractor into the lake.
