blahthisnamenottaken
- Joined
- Jul 25, 2002
- 12
On my 1963 75hp Evinrude, there is a small port on the lower unit that I cannot identify. I have all the manuals, and yet there is no mention of it. The port is on a plate called the "water bypass" plate in the parts manual, so I assume this is my water bypass port (or hole). It is threaded to take a plug, but there is no plug installed.<br /><br />Is this used for flushing the motor? Should it be plugged for normal operation?<br /><br />Behind the plate is basically a small empty cavity with a shaft running through it. I assume the shaft is the water pump shaft, but I'm not terribly sure.
