Re: What kind and size drill bit for powerhead bolt removal processl
ill go through it again.
I use the Dewalt TiN bullit point bits with a no slip shank.
3/8ths can be used, sometimes I use a 1/2".
depends on how well my eyes are focusing.
if your really really good you can use a 5/16ths.
nice thing about the bullet point is the dont walk if you partially miss the bolt diameter and the tend to cut a relativly flat hole.
get up as close to the powerhead mounting face as possible and try to drill perpendicular to the bolt and in the bolts centerline.
the object is to cut the bolt in two.
after the head comes off force the remaining broken stud from the midsection by driving it UP. dont even think of going DOWN.
