FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
What kind of glue should I use to glue the cushions to the plywood...I'm using regular OSB board and cushions from a couch I tore apart. Thanks in advance for the help
I Like 3M Super 77 Spray Adhesive. I also like to cover the foam with plastic using the spray glue. I used plastic bags from WalMart. Worked Great!!! Cheap Too!!!
Lol...I was planning on doing that too over the cushions to keep from chaffing the cushion...do you advise a layer of plastic between the wood and the cushion also?
Nope, none needed but I did glue it to the wood! Again, I'd use Ext. Grade plywood and I'd either paint it or at least give it a couple coats of Boiled linseed oil or marine varnish or polyurethane to seal it from the elements.
