Re: What kind of motor?
It's a late 1970s early 1980s 25hp. It uses the "old" style lower unit with the solid hub propeller, which eliminates the 30 or 35hp as a possibility. Also, the block isn't black, which makes it no newer than about 1985 (which means it can't be a late 1980s 28-SPL). Also, it has had the coils replaced at some point, as the plug-on spark plug leads came in about the same time as the black blocks, if not later. There should be a nickel-sized silver plug on the block somewhere with the model and serial number repeated from the (missing) leg tag.<br />- Scott
