What kind of paint is this?
CLL2437
I finally bought my first boat and now I need a little help with a paint question. I have read most of the post here and really enjoy all the tech help that you all share with each other. I’m sure I’ll have a ton of questions about various things in the future but for now its just about paint. The boat has a small damaged spot in the hull that I need to fix but it is covered with some kind of textured paint all the way around the boat. I think it’s for the water line. I have read a lot about bottom paint bout didn’t see any that is textured.<br /> Does anyone know what the best paint to use for this is? I will probably repaint the whole bottom so color match is not that important. <br /><br />Thanks <br /><br /> <br />This is the picture of the paint and crack picture
jimmythekid
Re: What kind of paint is this?
no pic for me either, but my bottom paint is somewhat textured, kinda like real thick paint
jimmythekid
if it turnes out to be bottom paint, they sell a speical remopver for it
18rabbit
Welcome to the board! :) <br /><br />That ain’t paint! That’s a chunk missing outta your boat!!! You have some work to do before painting. Can’t really tell what kind of paint (gray?) that is. Could be bottom paint, its not always textured. Only textured paint I've ever seen is bottom coat. If you are going to be leaving the boat in water for 4-days or more at a time, a barrier coat and/or bottom paint is a good idea. If you will be trailering the boat (day or weekend use) you don’t really need bottom coat. You can contact the folks at Interlux and ask them to send you a copy of their Boat Painting Guide. Should be helpful for painting any parts of the boat. While you’re waiting on deliver you can do something about the missing piece of your boat. :) <br /><br /> http://www.yachtpaint.com <br /><br />Edit: I was able to pages thru all of your pix. Yup! That’s bottom coat. Btw, nice boat in the world’s skinniest garage.
CLL2437
I will fix that cracked spot before I do any painting. I’m just reading all I can about how to fix it. It seems there are a lot of different ways to fix it.
Realgun
The way I have read here and planning on my boat is to grind out a bit of the damage in a dish shape. Then mix epoxy with glass fibers and or silca stuff or marinetex and pack it into the hole but making sure not to put to much. let it dry, sand, and paint.
