what kinda gear oil
lordblitzalot
i am wanting to check and change the gear oil in my outdrive before i go out monday and i need to know what kinda gear oil to use, and if there is anything special i have to do in order to check/change it.
it is a volvo penta motor/outdrive on my 71 glastron 21'
captmello
Re: what kinda gear oil
What outdrive do you have, 270? All the older volvos take motor oil. Straight 30.
2.25 - 2.75 quarts. Buy a pump at your local marine supply to pump the oil up into the drain hole on the bottom of the drive (with upper plug/dipstick removed). Fill to operating range by checking with dipstick. Once level is where you want it, install dipstick, remove pump from lower and replace drain plug. Can be a little messy.:)
You should replace the orings on the drain plug and dip stick.
Pretty simple proceedure really.
Good Luck!!
HT32BSX115
you might need to get the model/serial number from the drive itself
Go to http://www.volvo.com/volvopenta/glo...s_service/oil_information/oil_information.htm
and "rightclick/save as" the following link for http://www.volvo.com/internet/vebiz...9-8342-1a8d54f0f60a&area=VolvoCom+Volvo+Penta
It should indicate what yours uses...
Regards,
Rick
lordblitzalot
Don S
Two things,
1. What is the engine model number
2. What is the numbers on the tag circled below.
attachment.php
That top screw in the cover is actually a dipstick for the gear lube oil level
and the picture below is a screw that holds the bearing carrier in the drive, not a fill screw.
http://img509.imageshack.us/img509/2194/sl371401cz0.jpg
