Re: What lower units would fit a 1990 Force 120 hp? PLEASE HELP!!!!
As long as both engines are the same length--that is either 20 inch or 25 inch the 1991 will fit. Additionally, if your lower unit has a two piece drive shaft and the new one also has a two piece drive shaft (Which I am pretty sure they both do), then length does not matter. You can use your existing upper drive shaft.
However, do try to insist that the upper drive shaft comes with the unit you buy. They are or were very expensive and difficult to get so having an extra will never hurt.
