What Make Is This Boat
Hi all, New on the forum and last fall I bought a boat but the person didnt know make and model etc. Hopefully someone can help me. It's a 15.6 feet fiberglass. here's a few pics. I'd like to know more info on this boat, like year, max hp motor i can put on it etc.
Thanks
Re: What Make Is This Boat
Ayuh,... What's it say on the Title/ Registration,..??
capt sam
I don't know what ayuh means but I agree with what he says^^^^
Frank Acampora
Whatever it is, it looks like it is from the early '60s. Look at the Jetsons type dashboard. Oops, sorry. Not many people remember the Jetsons. Meet George Jetson--His boy Elroy--Jane, his wife, his daughter Judy, and Astro, his dog. I think I have the order incorrect though.
QC
insert local phrase here...
I would, but I don't think Ayuh = bitchen which is the bitchenest word ever . . . I am thinking 'sup is pretty close as you noted. We might even need a sticky for Ayuh, it messes up a lot of people :eek: :D
RotaryRacer
If I were to guess I would say Larson or Starcraft. Those are just two guesses. There were a lot of boats made back then that look very similar.
Check out www.fiberglassics.com. They are rebuilding the site right now so not all the links work. However, you might stumble across something.
tashasdaddy
yeah, it is a 60's there is a 60's johnson on it. they all copied each other back them. but has a short forward deck.
Chris1956
I had a '67 16' Winner that looked something like that. One of the more interesting things about that Winner's hull was it was a straight deep vee hull, that did not flatten at the stern like most boats. The hull design tended to make it ride dead flat in the water (no bow lift), and rise straight up, as speed increases until the prop would ventilate, especially in turns at speed.
Hi, the guy didnt have any papers for it and I have to get my buddie to fix the motor, all it needs is a coil and I forget what else
rjwoodrome
Seems to me the USCG has a section in which the hull ID number can be entered to find out what it is. Usually found on the starboard aft section inside and outside. it should be there unless the the fiberglass has been re-worked..
starsnstripers
Hull Id #s weren't required until 1972. May not have any, Ayuh!!!
There is a small plate but nothing with a SN, model # etc. I'm in Canada and I hope i wont have any probs registering the boat.
starsnstripers
When you go in you tell them that it's older than a 1972 when hull#s weren't required by law. use a bill of sale or previous owner reg #s if available. If not they'll issue you #s for identification.
ok, yeah I didnt get a bill of sale, I didnt think i'd need one, was an old boat and paid $550 for it.The guy never botherd to register it, thanks for the info.
Cheers
