What manuals do you recomend if any for my motor? Model: 856X4L
I've found two different ones.
http://cgi.ebay.com/ebaymotors/FORC...tegoryZ31284QQihZ016QQitemZ260120583260QQrdZ1
http://cgi.ebay.com/ebaymotors/FORC...tegoryZ26453QQihZ017QQitemZ270123147856QQrdZ1
and then a cd-rom manaul.
http://cgi.ebay.com/ebaymotors/FORC...tegoryZ26453QQihZ020QQitemZ300114865991QQrdZ1
Before I get a manual, what mainenence do you suggest for a new to me used motor? I don't think the previous owner did much maintenence.
Plugs, wires, and gearcase lube? Anything else? ANyone know what spark plugs? There are autolites and NGK's in there now, so I doubt they are the right ones. I plan on running some carb cleaner through the carbs and maybe some seafoam in a tank of gas and see how it runs before I pull off the carbs. I can't help but think that after all this time they are most likely dirty and need to be completely pulled off and gone through?
Where do I fill and drain the gearcase lube? I saw what appears to be a drain/fill plug up by the engine underneath the engine cover. Is that the right one? Or is it on the bottom half of the gearcase like the 84 merc that I have worked on?
It uses 50:1 oil mixture and any two-stroke outboard engine oil will work right?
THanks
THanks
