Re: What marine tex Product for simple holes??
Simple holes in glass hull what marine tex product do you use to fix these? Also are these perminent fixes? A link would be cool! Im thinking about grinding out the hull and glassing and glassing and glassing with mat roving mat roving mat to fix a couple screw size holes in the hull. Id rather use this stuff if i can. Any advice what you guys are useing as far as what marine tex you are useing.
Many have advocated Marine Tex for such things. I have found it totally unsuitable. It is very hard to mix (5 to 1) in small quantities and it is very runny. One thing I have not tried is to mix in some cabosil, glass bubbles or micro fibers to make it a better putty.
I have always used thickened epoxy resin for such patches. With a 2 to 1 or 3 to 1 mixture it was always easier to mix up. The consistancy of the resin and the hardener made it easier to dose out. I think that thickened polyester resin, in small batches would be next to impossible.
